Beneemt P1 dongle does not connect to HC3
Guest theoverriet
Guest theoverriet
I try to connect a BeNext P1 dongle to the HC3 (it was connected successfully to the HC2 before). The process stops half way (the screen where you normally would see the added devices stays empty) leaving me with a dongle with a red solid led (meaning it is connected with a wave network), but in the HC3 there is no device visible. What to do?
Also used this thing, even contacted BeNext support. No response. It's landed in the bin. I'm now using P1 monitor from @SmartHomeEddy. Works like a charm
