The time on the display of the MCO MH7 is shown incorrectly again
Maybe, just maybe - if the MCO takes the time from your homecenter you have set a incorrect timezone ?
Or, if the MCO sets the time itself it doesnt have a daylight saving setting ?
Anyway maybe you can provide a little more info.
Soft reconfiguration device and MCO MH7 takes time from HC3
Yes... soft reconfiguration is the way to go..
I've been doing this for years :(
    Thanks, restarting the Home Center solved the problem.
    • 4 months later...
    Hey, I have a same problem with my setup - I own Fibaro Home Center 3 Lite and four MCOhome MH7H-WH thermostats
    Everything is working fine except for time/clock synchronization - HC3L time in dashboard is correct but on thermostats it shows wrong time - rebooting HC3L, trying to remove and add thermostat again etc. nothing helps
    Can you guys please let me know what to do to get time synchronized?
    @MIKEsome
    If you've tried soft reconfiguration and it didn't help, turning off the power supply for 1 minute may help. Check if you have pooling enabled from HC.
    W dniu 7.03.2023 o 18:51, Martin_N napisał:
    @MIKEsome
    Thanks I’ve tried to soft reconfigure as well as turning off :( but what is „polling” ?
    I have managed to fix the problem - I had to reset Home Center 3 Lite to factory settings and during setup choose zwave 2 instead of zwave 3 beta
    now time is properly synchronized with mh7h-wh thermostats
