Am not able to wake up any of 5 Fibaro motion sensors
HC3-00001183
Does anybody know what I am doing wrong? As I can see in HC3 all of these ones are marked: Wake up interval: 0s. That I am not possible to change. If I do, it just go back to 0s again. Then I try to wake the sensor up by clicking it 3 times as I should, but nothing happens. Tried also to reinstall and install again... With a same problem. (Have another 6 of same type that works perfectly)
Would appreciate some guidence 😅
Lars
Are you using old FGMS (ZW300) or new ones (ZW500)? You can check it in device settings, version 2.x is an old one and 3.x is a new one.
If those are old ones and you are using new ZW3.0 beta devices are supported in generic way, you should be able to alter wake up interval to few hours and it should be saved correctly after triple click.
Welcome to the forum @HC3-00001183
For a relative old HC3 (1183) it took you some time to come to the forum 😁
  • 3 weeks later...
    Well, SH Eddie. It even took longer time than that. Before this HC3 I had the HC2 for many years. ☺️
    Better late than ever, Thanks
    I use them both, But the ones I am struggling with are FGMS001. Now I am able to wake them up, (even if led lights does not say so) I have now tried both to connect them to lightnings handled by wall plugs in 2 different ways: By association and by block scene. But it does not work at all. No reaction in lightings. I can say that same lightnings are also connected to another motion sensor (Entering the room from other door) and that works just fine. Have reainstalled but it does not help. Can also not update it to latest firmware. Now 4.6 on 2 of them and 2.7 on three others. As I see in HC3, 2.8 is the latest. A bit lost here... anybody that can help?
