Neo Andersson 149
If anyone by chance had some difficulties with setting up IOS devices for using SIRI commands, here is a description. As probably anyone can know from Fibaro manuals, that SIRI coomands can be used only through Shortcuts / (it is an application in IOS systems, so download it first)
Initially we had problems with shortcuts, becuase not all of Fibaro scenes used to show up in available / selectable scene's list for certain shortcuts, and we were not able to determine, why some scenes are not showed up and some scenes are.
Today i finally got the answer, so i wanna share with you what is the trick behind it, as it is not described in any Fibaro manuals.
1. So first of all, create a shortcut in IOS device. (in the Shortcut application)
2. Select Home center app from the list of avilable applications (after pressing the + button for creating a new shortcut)
3. Select the scene from the list that you want to be run by SIRI voice commands.
And here is the trick..If the scene is not visible, that you are looking for, it is because only the FAVORITE scenes will be available..So head back to your Favorite panel, and make the desired scene as Favorit, then you will be able to see it, and select it for a Shortcut.
From that point on, you will be able to use a SIRI voice command, to activate your scene.
I hope this will be helpful for other users, becuase to be honest, we couldn't find this answer nearly one year...
7 answers to this question
