need to sent two http Commands
meijer
Hello all
I have a automatic drawer opener.
It has its own website to make configs, but also you can open the draw via a http command
when I type http://192.168.173.209:81/login
I get a login screen
when I type
It logs in and shows the webpage of the drawer
When I type
push
The draw will open
So i need to sent two
Http urls
 (to login)
push (to open draw)
Did some reading but and came up with the following code in a VD:
local connection = Net.FHttp("192.168.173.209", 81);
local command = "/login?pin=hallo";
local command2= "/push";
connection.GET(connection, command);
connection.GET(connection, command2);
Can see in a debug mode what I sent as command?
I get no error messages but nothing happens
Thanks in advance
HTTP calls in the HC3 are asynchronous. This means that if you run the two requests after each other, the second request will already be executed while the first is not yet ready. To fix this use this code:
Note, this is simplified code as an example...
Edited by Joep
Error in code.
    /monthly_2023_03/image.png.e1f518c2ed6168d2384fea924097b62f.png" />
    Thanks Joep,
    I get an error message: attempt to index global 'net' (a nil value)
    I hoop you can help me
    Kind regards
    Gert-jan
    I made an error defining the http module in the wrong scope (local). I edited the code in my previous post.
    Hello Joep
    This was not the solution for me.
    /monthly_2023_03/image.png.969151673c1cbf5579528c9c9f2599b1.png" />
    When I change the net.HTTPClient INTO Net.HTTPClient So with a capital N I get a different error
    Could it be that I don't have the net.HTTPClient  class?
    I have a HC2
    Gert-jan
    Edited by meijer
    On 3/16/2023 at 11:51 AM, meijer said:
    I have a HC2
    I gave you code for the HC3. 😀
    This is a HTTP call on the HC2:
    Edited by Joep
    fix: error in success function
    • 5 weeks later...
    One thing you could try is to print out the commands using the debug function to make sure they're being sent correctly. You can do this by adding the following lines to your code: bash Copy code local connection = Net.FHttp("192.168.173.209", 81) local command = "/login?pin=hallo" local command2 = "/push" print("Sending command 1: " .. command) connection.GET(connection, command) print("Sending command 2: " .. command2) connection.GET(connection, command2) This will print out the commands to the debug console so you can see exactly what's being sent.
