zubek34 0
Hi, last year I installed 4 channel relay switch to control valves for sprinklers. Now I'm about to turn watering on again but I have a problem. No matter which valve/switch (or assigned fibaro sprinkler) I'm trying to turn on, always first channel is turning on. For example I want to turn on valve with id 102, when I click it I can see on UI (and in my garden) that actually valve 101 is turned on. When I want to turn it off it doesn't work unless I click valve 101 (the one that actually was turned on).
Can anyone help me with this? It was working perfectly fine last year (and it is still working when I'm physically toggling them).
