Door window sensor and two DS18D20
Can I connect two temperature sensors  DS18D20 to d/w sensor ?
Of course I can connect two DS18D20 sensors in parallels way (elecrically) bat my question is can Fibaro HC2 control/support thise configuration and as a result I get two temperature icon.
@Mieszko64Hi, If you have the Fibaro FGBS-002-2 Door-Windows sensor, the answer is no.
To have the temp sensor DS18D20 working, I always use Smart Implant
. You can connect up to 6 DS18D20 to on e SI.
    THX
    Got it - In my case/by manual (technical spec.) -> only single DS18D20 sensor!
    Edited by Mieszko64
    @Mieszko64You can connect up to 6 DS18B20 sensors to the smart implant. Look below.
    I've done this quite a few times trough the years.
    I always use:
    Power Supply 12V 2A
    DS18D20 Sensors with 3m cable already assembled
    If you add or remove a sensor, you have to exclude/include smart implant again to the homecenter.
    Make sure you have stable connections between the smart implant and the sensors.
    Edited by Fabir
    • 3 weeks later...
    THX
