Aeotec Multi sensor 6
Sjakie
Two out of 6 multisensor failed, soft reconfigure did' solve the problem. Excluded and included, device does't work anymore.
Lux, humidity and temperature are all working. Pir stucks
If add sensor it show on first screen only one device, light sensor,  instead of 6
5.130.64
 No problem to add sensor and is working without any exception.
Regretly I can't use that previous fw because to many devices  build in
How to tackle????
Edited by Sjakie
add number devices
@SjakieI've had this issue too with aeotec MS6. Try set parameter 5 to 2.
In my case this has solved the PIR stucking.
    @Fabir thanks it did't help
    @SjakieYou're welcome.
