Remotec ZXT-800 - Fibaro HC 2
karaokek
Honestly, I have really tried my best - but getting nowhere.
So, I have a Remotec ZXT 800 together with an HC2.
What do I want to achieve – to use the AV setting to control my electric curtains.
Using the ZXT 800 AV IR learning function
Let’s say Vol+ = Open
Let’s say Vol- = Close
Let’s say Mute = Stop
I have added the ZXT800 to HC2 and it is showing in the system.
But it is not configured - this is where I am stuck.
Configuaration boxes to fill in are –
Number,
Data Type (option 1d, 2d, 4d)
Desired value
Read only – check box
Default Value.
Should be easy – but not for me.
Any help would be so much appreciated.
Thanks in advance
Edited by karaokek
wrong word used
    Re the above, I have had the following reply from Remotec
    From
    Hi Clive,
    I think it doesn’t show AV interface yet on HC2, right? We are still working with Fibaro to release support for AV function, it shall be available after 1 month.
    Once it is available, you will be able to see 3 channel AV device after add it to Fibaro. And then you can learn your curtain remote into ZXT-800 by configuration.
    Best regards
    Vincent
    I will post any info I get from Remotec.
    Hopefully it will be resolved as the unit could be very useful for "infra red" and Z wave integration.
    • 3 months later...
    An update from Remotec
    Fibaro will release for next version which plan in mid of Dec as they said. Let's wait. You can also use our Conexum App for ZXT-800 to try out learning with your curtain remote.
    • 1 month later...
    I received the following message from Fibaro
    Remotec ZXT 800 and HC2
    __________________________________
    Hello
    Thank you for the message!
    I needed to consult with my colleague who is responsible for Zwave integration.
    I received a message from my colleague this morning with information that for now, we have no full support for this device on Home Center 2.
     Unfortunately, I do not have any information about if and when the full support will be implemented.
    Have a nice day.
    Following that message I purchased a Remotec ZXT600
    I am glad to say that the ZXT600 works.
    My electric curtains now controlled by HC2
    I have posted my ZXT600 findings under
    "ZXT-600 use as a learning infrared"
