A RefreshStateSubscriber class has been added to handle system events with methods for subscribing, unsubscribing, and starting/stopping event listening, providing better control over event-based actions.
How to use please?
I will share tomorrow docs here, we are in the progress of updating manuals.fibaro.com but it will take some time.
Quote
Class for handling system events.
RefreshStateSubscriber class methods
RefreshStateSubscriber classe constuctor.
Example
RefreshStateSubscriber.subscribe(filter, handler)
Add a listener for system events. Returns subcription
Parameters
  • filter - function that will be fired when the event occurs. Have to return boolean.
  • handler - function that will be fired when the filter met conditions.
Example
RefreshStateSubscriber.unsubscribe(subcription)
The method removes subcription
Parameters
  • subcription - array recieved from RefreshStateSubscriber.subscribe
Example
RefreshStateSubscriber.run()
Method for starting to listen for events.
Example
RefreshStateSubscriber.stop()
Method that stops listening for events.
Example
  • Thanks 4
Hi Michal,
RefreshStateSubscriber is a great new feature that simplifies the combination of QAs and scenes and will definitely help to reduce the load on HC, as now it is not necessary to run scripts in QA so often.
Is it also possible to use global variables as triggers?
I think events like changing the value of global variables are not in the event log.
Thank you
3 hours ago, marbe said:
Hi Michal,
Thank you
It is.
Maybe someday we will get a list of all of them....
Yes, it works great, thanks'!
May any1 have an exampel of how to use it in a QA to check if a Dimmer 2, S2 input is triggered?
  • 4 months later...
    Anyone has a list of all the event types that we can listen to?
