Flush Dimmer 0-10V - temperature sensor
petro_cz
Hi, I bought this device to control my boiler, https://www.fibaro.com/compatibility/qubino-flush-dimmer-0-10v-2/ , but Fibaro won't find my temperature sensor, I have it plugged in. Is there a trick to this? ( I don't have the original sensor, but it's a classic DS18B20. ) Thank you.
@petro_cz
Are you absolutely sure that your DS18B20 is compatible with the original Qubino sensor and that it is correctly connected to your Flush-Dimmer?
The sensor must also be connected when the device is included and cannot be connected afterwards.
  • according to the description, it's the same sensor
