Samsung Smartthings and HC3
Martin555
I would like to integrate my samsung washing machine into the Fibaro HC3.
Where could I download QA Samsung Smartthings or some QA for Samsung washing machine?
It possible to conncet to wahing machine via LN directly without Smarthing cloud?
Thank you
Edited by Martin555
5 answers to this question
  • I started working on QA for SmartThings and my Samsung washing machine. I managed to get some data into the Fibaro HC3. I have some data.
    If I use this adress
     I get data and for example this:
    [27.12.2023] [20:38:00] [DEBUG] [QUICKAPP1611]: Manufacturer: Samsung Electronics
    [27.12.2023] [20:38:00] [DEBUG] [QUICKAPP1611]: Device Type: Samsung OCF Washer
    [27.12.2023] [20:38:00] [DEBUG] [QUICKAPP1611]: DeviceID: XXXXXXXXX
    if I use this adress
     , XXXXX is your ID for device long number I get data.
    Can someone help with creating QA for HC3, Does anyone want to participate in the development?
  • I did it .
    You need:
    1. SmartThings
    2. SmartThings Instaled app ( I created it from Homeassistante)
    /monthly_2023_12/image.png.4f7c1a75ecc178e6ee1c1d537226886f.png" />
    Edited by Martin555
    Hi, can you describe how you did it? I am interested in integrating Samsung devices with HC3
  • On 1/5/2024 at 10:02 AM, wojtas810 said:
    can you write something more? share Quick?
    You need to create personal acess token and registrate to smarthing.
    I proceeded for the initialization on the smarthing client and the creation of the instruction token on the hommeassistant client. I also instal this aplication for homeasistante and after thet it was possibleto put in hc3.
    It's because I created a token at the beginning, but I didn't know how to register the application on the smartnihg page. When I installed it in HA, a connection to my account was created on the smarthing client, and suddenly I already had data.
    A)
    I think that you have to proceed according to this instruction A), but I got around it by installing it on HA as well.
    After thant I cerate QA. It is working.
    It's still under development, but I don't have much time to solve it
    If you will need help send me message to Messenger martin.potocky.18 alebo whatsup 00421905623993
