bsh21 0
Hallo,
i will switch from Zipato ZWAVE System to Fibaro HC3 an have some Problems with the integration from the existing ZWAVE Components from the Zipato System..
1.
I have some Aeotec Smart Switch ( 2 x Aeotec Smartswitch 7 & 1 Smartswitch 6) an have it in Inklusion Mode but Fibaro System do not find them when i will include them.
2.
The existig Smoke Sensor from Zipato (ph-psg01) are not shown whe i want include them - the Fibaro System do not find them when i will include them.
Is there any way to include Components from other Manufacckture or run only Fibaro Componets? When only Components from Fibaro run or from the Compatibility i have a bigger Problem.
I hope that i find only one Function in the gateway not to include them.
Thanks for the Help.
