A critical error occurs when the air conditioner controller integrated into the HC3 controller cannot be controlled via the Yubii home center app
Duy_Minh
Another important issue is: when integrating HC3 with intesis code INWMPDAI001R000. When using it for home control and using it on the web, there are no problems, but when using the yubii home center app, it cannot be controlled. although I have tried with other intesis devices and they are fine. Has anyone had the same error as me and is there any way to resolve it?
Hello. That has already been reported here:
As it looks, it is a plugin issue related with the access outside your local network.
The beta version in my case solved it.
I also had this problem for almost two months. We discussed it in this topic.☝️
But about a week ago, everything worked for a reason I don't understand.🙃
Now everything works fine both locally and through the cloud.🙂
I have HC3 firmware beta 5.150.18 and YubiApp 1.121.0
