HC2 - some actors stopped executing commands
Vladyslav_UA
Probably, somebody can help.
 HC2 firmware 4.63
A week ago some actors stopped executing commands On/Off
List of them:
- Fibaro smart plug;
- Fibaro double switch 2;
- Aeotec Heavy Duty Switch
No enegry consuming indicates or indicates permanent wrong values in browser interfaces.
At the same time the rest of the same devices staying good.
No rebooting, nor the soft reconfiguration does not removes the issue.
What is happend? How ti solve the issue?
Thanks in advance
Did you try a soft reconfiguration or a complete reset?  If that does not help, pls consider that the modules my wear out (esp. the smart plugs - had a lot of them dead after 3 years) after a certain usage time.
    The actors indicates as fully working in web-interfaces, taking on and off. but does not turning their state in real
    Hi @Vladyslav_UA ,
    I my case i had to forcibly delete fibaro plug and then include it again. This happened to me several times with fibaro plug, fibaro eye and once with Aeotec HEM.
