Heating Panel not doable with HC3 Lite
Tullball
Hi there
I've been using Heating Panel in HC2 and HC Lite for a long time in different places, with the Fibaro motion sensor,
, and different switches. This has been a great success.
I now bought the HC3 Lite for a new setup with the same Fibaro Motion Sensor,
, and Fibaro Wall Plug,
. Is there a change here? It doesn't seem like I'm able to control panel owens with this equipment. I've found stuff around virtual termostats, but haven't been able to make it work.
I hope someone can help me, or else I have to buy an old HC Lite which I know will solve this issue.
GT
Tried the linked devices?
go to Add devices and other:
/monthly_2024_01/image.png.42b30a8ce9e2457a302e8797c58b24b4.png" />
  • Hi.
    Yes, I had added it, and couldn't understand anything. I tried again now, and now it works, and I can add zone. Strange.
    GT
  • This is how it looks now. I've created two zones, set temperatures, and things seems to be working. But I've lost visibility on room temperature and electricity consumption. Is this a side effect of the setup?
    Well. I can see the total consumption on the Yubii app, but not in the web gui. But I can't see the temperature anywhere. Why? Have I done something wrong?
    This is what I see:
    You forgot to uncheck this, it can be fixed by going to setting-> devices->.....Se below this pic
    /monthly_2024_01/image.png.9afdf36c52b06f1f7cb3edccb3227d1c.png" />
    then go to filters and show hidden, then find the missing temp and relay you are missing :D
