Database with default setting
aLinux
Hello everyone
I'm new in Fibaro's world and I'm study to integrate Fibaro HC (or HC lite) with my application. I need a database to try my  code. Could someone give my a backup or a database? The data are not important a default setting is enough.
Thanks a lot to everyone will help me
Hi @aLinux ,
I'm trying to understand what database you are talking about. Fibaro HC boxes are security protected same as their backups so you will have no use of it. There is a way to do some programming and testing from IDE like Zerobrane Studio or Microsoft Visual Studio, but without having HC this is similar to trying to taste food from empty plate.
    Hi
    I'ld try to execute update directly to db through  ssh connection ( I've read it is possible ). So if I know the db structure I can test the command line
