What is the loop equivalent "while true do"
RBebenek
In HC2 Lua I was used frequently loop "while true do ".
I can't find similar or rather the same "construction" on HC3 Lua.
Would like to reduce number of scenes (especially in case of HC3-Lite, where no of scenes is strictly limited).
For example global variable definition (day/night) in one scene, on HC2 looks like:
%% autostart
%% properties
%% globals
while true do
  -- downloading the current time, sunrise and sunset time
  local sunriseHour = fibaro:getValue(1, 'sunriseHour');
  local sunsetHour = fibaro:getValue(1, 'sunsetHour');
  -- recalculation time to the number of minutes from the sunrise
  local currentMin = tonumber(currentDate.hour) * 100 + tonumber(currentDate.min);
  local sunriseMin = tonumber(string.sub(sunriseHour, 1, 2)) * 100 + tonumber(string.sub(sunriseHour, 4));
  local sunsetMin = tonumber(string.sub(sunsetHour, 1, 2)) * 100 + tonumber(string.sub(sunsetHour, 4));
  -- settings global variable  "Day"
  -- value is calculated every 60 sec.
  if
    (currentMin<sunriseMin)
      or
        (currentMin>sunsetMin)
    then
    fibaro:setGlobal("TOD", "Night");
        fibaro:debug("Global Variable Time Of Day is : Night");
  else
    fibaro:setGlobal("TOD", "Day");
    fibaro:debug("Global Variable Time Of Day is : Day");
TOD stand for Time of the day.
Will appreciate your kind support!
