bikerdude 0
Hello all
I have a double switch 2 (FGS223) connected to a dry switch which in turn is connected to a pellet stove and controlled via home assistant.
I had this switch for many years and all was well
Last spring I had a failure on the pellet stove where i had to replace the pellet stove on/off switch. This meant that to identify the issue i had to remove all components.
After the re-assembly if the components an re pairring the fibaro switch all worked well so i thought.
My automation requires to verify that if i am home between 07:30 and 22:30 and that the room temperature is below 18.5 deg.C. the pellet stove turns on.
during the winter and spring it worked flawlessly.
Now to temperature is always above 20 Deg, the pellet stove still turns on at 7:30. THI IS THE ISSUE.
I deleted all automations form home assistant (except for light control and geofencing) and the fibaro switch still turns on at 7:30
Therefore i assume the issue is in thew switch settings.
In looking through the settings of the switch via z-wave js i do not see any issues that would cause this
I enclose a copy of the setting for this fibaro switch
Can you please guide me and find what is causing this switch to activate
Thank you in advance
