Rossinyol 0
Hi everyone,
I just bought 2 MH8-FC from MCO home. At the beginning both devices were working fine, but couple of weekes ago, the room temperature was higher than it should be. I've checked with other temperatures sensors and all of them are between 2,5 and 3 degrees lower than the MH8-FC.
Ive noticed that room temperature increases when the device thermostat is on, it seems to be that the sensor is getting sme of the heat from the inside electronic. Does anyone had the same problem?
