Hello from Australia
Perinoz
I am new to fibaro. I am migrating from an Environexus/Nero system which I installed 7 years ago. I am currently playing around with scenes and I have run into an issue.
I have set up an automatic light turn on every night at sundown. I then disabled the scene; however, it still runs.
Hi and welcome. I am also in Australia, sometimes I find it takes 24 hours for some of my scene changes to settle down / come into effect. This makes no sense to me and is not all the time, but I think sunset and sunrise related scenes are impacted more often than not on my system
I assume when you say disable scene, you are using the activation toggle on the scene list
 - How long have you left the scene disabled for?
 - Are you sure there is not another scene that is triggering the light on?
 - Is the light only set up in Fibaro? Are you sure it's not in another eco system with a scene that is triggering it on
    I also had a scene which should only be active in "away" mode. I have now disabled this as well to see if this caused the issue. I did have the scene disabled for several days without any effect.
