Zooz Outdoor Motion Sensor ZSE70
mike9
Hi, I am new to this, so be kind!  Has anybody successfully added the Zooz Outdoor Motion Sensor ZSE70 to an HC3.  I have just bought the device and cannot get it to add.  I have tried factory resetting the motion sensor but the HC3 will not recognize it.
Any thoughts?
2 hours ago, mike9 said:
Have you tried to include it with S1/S2 security?
Hi @mike9 and welcome!
Are you sure that your HC3 and ZSE70 are working on the same z-wave frequency? I found ZSE70 but only with frequency for CA/US/MX and I guess your HC3 is on EU frequency and therefore doesn't see it 🤔
It should work with Z-box hub which is US version of Fibaro HC3.
Edited by Sankotronic
I guess  you got it from here?
@Sankotronic it is actually just realised a eu version of them :D
I got 1 to :) I got it in my home senter 3 with z-wave engine 3, but havent tested on the z-wave engine 2 🤔
Edit:
moved it to z-wave engine 2 without problems   🤔
So I guess @Sankotronic might got a point to check the freqency  🤔
Edited by Brors94
