i just wanna say Hello and ask about a topic
Hello  everyone ,
any time when i replace a battery  at fibaro  doors   battery icon remain  red as it was  discharged .
I did replace with open doors , with closed doors,  did activate , arm disarm  , anything.
Only  removing for HC 2  ( my existent sistem )  and  reattaching to home did change battery status.
any  ideea?
After a battery-change you have to click the activation button or wait for auto-wakeup.
    i  did click to activate  and nothing .  Sometimes  fibaro door act  strange .
    Today i took out batterry with door open . Then  i dont know  what i did in settings  that asked on all  icons  from root   to activate. Touchen back button 3 time and worked .
    Edited by bogdanciobea
    Yo, that‘s what I meant : Clivk 3 times to wake-up …😎
    • 2 months later...
    In my experience, waking up the device manually usually does the trick, but if it doesn’t, re-adding it (like you did) is the most reliable fix. It’s not ideal, but at least you’re not alone, many users run into this quirk.
    Edited by KylerJeremy
    After removing battery in many cases it helps to clean battery contacts on DW sensor, actually on all battery operated devices before inserting new battery. To clean, best choice is to use electro-cleaner applied to a soft tissue, but if you use knife or any other metal object that has no sharp and teethed edge to softly scratch contact is also OK, just do not use to much force not to damage surface of the contacts.
    Also, in most cases device wake up it self as soon as battery is inserted, if that is not the case, even after cleaning contacts, then just remove battery, wait for few seconds and then reinsert ne battery. That should do the trick.
    I have many Fibaro battery powered devices and I never needed to re-add them after battery replacement.
    Just remember that it helps to use recommended battery type. If you go for anything else or recharged batteries then most probably battery status will fail.
