Dear users,
Here are the key changes in API, scenes and QuickApp that the new version offers.
1. Added an option to define title to email notifications called from Lua (Quick Apps and scenes).
The email subject could be customized by adding an optional parameter to the method for sending an email to users:
In case of LUA Scenes:
In case of Quick Apps:
2. Added the ability to disable one log channel in Quick Apps using a dedicated function.
Quick App log level can be set using following assignment in the LUA code on Quick App:
where log_level could have one of the following values: NONE, ERROR, WARNING, DEBUG, TRACE.
Example to set Quick App log level to WARNING which will allow only errors and warnings to be displayed in console:
3. Added the request to synchronise the sort-order in the system according to administrator configuration.
New API endpoint was introduced to synchronize (reset) sorting order of devices and scenes for all users back to the order that is assigned to the admin:
Only admin, installer and support are authorized to call that API endpoint.
4. SNI TLS extension support for MQTT protocol.
LUA MQTT Client that uses TLS by default enables SNI TLS Extension by default since version 5.191. In case of some problems there is a possibility to switch SNI off by the following setting in connection
options:
*Behavior was changed in firmware version 5.200 in order to provide backward compatibility
  • K.Drozynski changed the title to Update 5.191 BETA: Crucial changes for API, scenes and QuickApps
