This is a forum thread how to integrate external location services to be compatible with the HC3 API and programming model.
The HC3 has locations defined in /api/panels/location.
A location has locationId, name, radius, latitude and longitude.
The HC3 has users, defined in /api/users
A user has an userId.
The HC3 also has defined user devices as api/devices?type=iOS_device
The map between device and user seems to be the lastLoggedUser property of a device device... (or??)
When a user moves, the HC3 posts a refreshStates event
This is translated by the HC3 to a sourceTrigger
That we can trigger on in Scenes (or using something like EventLib in QAs)
If we get location data from an external source, we can post a system/refreshStates event that gets picked up by the HC3
The HC3 don't deal with latitude/longitude in the events, only locationId, so we need to map the positions we receive to HC3 locations and then post the right type of event, when we are entering or leaving defined locations - and user/device it was related to. The API doesn't seem to be too picky about the device ID (if it is defined or not), but the users needs to be there.
As an example I have a small python app that can be installed with
It has a lot of parameters (see fibioslocation --help)
but it can be setup to post iCloud location data for your devices (family and friends) to a QA on the HC3. All data is sent to
Below is an example QA that uses that data to keep track if users are entering leaving HC3 defined locations and posts related events using api.post("/events/publishEvent/GeofenceEvent",...)
We setup what devices to track using the QA's quickAppVariables
-- <name>;<model>;<userId>;<deviceId>
-- If <userId> and <deviceId> are numbers, they will be used in the geofence event. Otherwise, the device will be tracked but no events will be published. The <name> and <model> fields are used to match against the name and model coming from the iOS data for the device.
Ex. a=Tim’s iPhone;iPhone 14 Pro;4;976
Please posts improvement or examples of integrating other location services.
