I wonder what‘s keeping Fibaro from implementing the new plugin … 🤔
    So, no comment from Fibaro?
    there is no need to wait for Plugin, use that perfectly working QuickApp
    It was commented before, we are looking into it.
    Its not on priority list, probably at some point new version will be there but for now, as @tinman suggested, you can use the QuickApp.
    Hi m.roszak, you can‘ t be serious about this - referring to a third-party solution instead of updating the „official“ plugin. Quite unprofessinal ☹️
    Never said, that the Yahue solution is stupid (quite contrary) - I don‘t just like Fibaro‘s attitude towards keeping their system up to date
    System has integration with various 3rd party elements but also handles a lot with the Nice ecosystem.
    Plugin for Hue is rarely used so priority is low for making a new one for V2 bridge.
    You are treating this as an update but its not, V2 API is something different (not minor changes, its just something completly new).
    I know you are the one interested on it, along with few other... But there is no company with unlimited resources,  we just can't cover all the requests at the same time.
    If proposing a 3rd party solution integrated with Hue V2 is not professional in your opiniton - you have the right to think so - I can disagree with you on that ;)
    If anyone wants any integration made by Nice / Fibaro, anyone can reach via
    . I believe that Official plugin is compatible with previous Philips HUE gateway with current firmware? Btw, even Cotnrol4 does not have driver for new Philips Hue gateway and 3rd party driver, which is paid btw, is needed and they have support for previous HUE Gateway.
    @m.roszak, any plans for more.niceforyou.com?
    I have a basic beginner question and would appreciate if someone could confirm my understanding.
    As I understand it, there are currently at least two ways to integrate a Philips Hue LED light with Yubii Home Pro:
    1. Include the Hue light directly in Yubii Home Pro as a Zigbee device. In this case, only the basic functions are available. For example, I can switch the light on/off, dim it, and perhaps change colors, but I cannot access Hue-specific settings such as the power-on behavior (e.g., after a power outage, return to 25% brightness and blue color instead of 100% brightness and white).
    2. Use a Hue Bridge, include the Hue light in the Hue Bridge first, and then integrate the Hue Bridge with Yubii Home Pro. In this case, the full range of Hue functions and settings is available.
    3. At the moment, there is no way to access the full set of Hue functions by connecting the Hue light directly to Yubii Home Pro without a Hue Bridge.
    Have I understood this correctly?
    My particular requirement is to have the light return to a predefined favorite setting (for example, 25% brightness and blue color) after the power has been interrupted and restored.
    Thank you very much for your help.
