power meter does not reset to zero when corresponding switch is turned off
1 answer to this question
Device is actively measuring the flow and reports are send not correlated with the state of the relay.
it can be for example sticked due excessive load and in this case power can still be drawn even if it supposed to be disabled.
You are asking about not having this instant after disabling the output or not having 0 at all?
