Good morning,
I would like to ask whether it is possible to disable the generation of trace-type messages in the HC3 console.
I do not mean filtering them out in the console, but preventing them from being generated at all.
In particular, such messages are generated by api.post and hub.call, starting with "onAction = {...}", which is very inconvenient for me with the current architecture of my QuickApps.
Perhaps it is possible to disable this for a specific application - that would be ideal. I remember that in posts about one of the firmware updates there was a mention of being able to limit or adjust the message level, but I cannot find it now.
Redefine the trace function in your QuickApp:
    Thank you very much, of course it works!
    I can’t believe I didn’t think of such a simple idea. I was sure it was going through some internal hub mechanism, and yet here we are.
    I've tried it this way, and it's working:
    Edited by Łukasz997
    There is also build-in log level setting in the quickapps:
    self.logLevel one of following constants: NONE, ERROR, WARNING, DEBUG, TRACE
