Good morning,
I would like to ask whether it is possible to disable the generation of trace-type messages in the HC3 console.
I do not mean filtering them out in the console, but preventing them from being generated at all.
In particular, such messages are generated by api.post and hub.call, starting with "onAction = {...}", which is very inconvenient for me with the current architecture of my QuickApps.
Perhaps it is possible to disable this for a specific application - that would be ideal. I remember that in posts about one of the firmware updates there was a mention of being able to limit or adjust the message level, but I cannot find it now.
Redefine the trace function in your QuickApp:
    Thank you very much, of course it works!
    I can’t believe I didn’t think of such a simple idea. I was sure it was going through some internal hub mechanism, and yet here we are.
    I've tried it this way, and it's working:
    Edited by Łukasz997
    There is also build-in log level setting in the quickapps:
    self.logLevel one of following constants: NONE, ERROR, WARNING, DEBUG, TRACE
    Thanks. And if I want more that one kind of info - the values can be combined like bit flags? or maybe table can be used?
    I mean:
    Specific level contains everything on it and higher levels, as typically in settings like that.
    So, for example, TRACE shows everything, WARNING shows errors and warnings.
    I'm afraid this is not functioning...
    self.logLevel = DEBUG does not cut TRACE messages.
    However DEBUG has non-nil value (3).
    Edited by Łukasz997
