TRAGEDY! With this new update, you’ve completely broken Zigbee!
The power-off workaround—doesn’t work.
Soft reset—doesn’t work.
Only rolling back to version “5.200.13” helped.
On 5.210, Zigbee doesn’t work at all. What a piece of junk you’re releasing!
    However, after a few minutes, Zigbee also stopped working after the downgrade! Probably the same issue as:
    WHAT DID YOU GUYS DO!?
    I am on 5.210.12 and have been for a few weeks. My Zigbee network is working just about the same as previous version.
    What issues are you seeing?
