TRAGEDY! With this new update, you’ve completely broken Zigbee!
The power-off workaround—doesn’t work.
Soft reset—doesn’t work.
Only rolling back to version “5.200.13” helped.
On 5.210, Zigbee doesn’t work at all. What a piece of junk you’re releasing!
    However, after a few minutes, Zigbee also stopped working after the downgrade! Probably the same issue as:
    WHAT DID YOU GUYS DO!?
    I am on 5.210.12 and have been for a few weeks. My Zigbee network is working just about the same as previous version.
    What issues are you seeing?
    Currently, all actuators (switches, outlets) are offline. Surprisingly, the sensors have come back online.
    Unfortunately, the option to reconfigure all devices in the Zigbee settings is disabled (HC3). I have about 30 Zigbee devices. Manually adding everything again is pointless.
