TRAGEDY! With this new update, you’ve completely broken Zigbee!
The power-off workaround—doesn’t work.
Soft reset—doesn’t work.
Only rolling back to version “5.200.13” helped.
On 5.210, Zigbee doesn’t work at all. What a piece of junk you’re releasing!
    However, after a few minutes, Zigbee also stopped working after the downgrade! Probably the same issue as:
    WHAT DID YOU GUYS DO!?
    I am on 5.210.12 and have been for a few weeks. My Zigbee network is working just about the same as previous version.
    What issues are you seeing?
    Currently, all actuators (switches, outlets) are offline. Surprisingly, the sensors have come back online.
    Unfortunately, the option to reconfigure all devices in the Zigbee settings is disabled (HC3). I have about 30 Zigbee devices. Manually adding everything again is pointless.
    Unfortunately, we are unable to resolve this issue on our side. This functionality relies on integrations and services provided by third-party vendors, and therefore its operation is outside of our direct control. As a result, we are unable to make changes to it or guarantee its proper functionality.
    Best regards
    Best regards
    This is clearly not a 3rd-party device issue. It is a crash of the HC3 internal Zigbee coordinator. The fact that the "Reconfigure" button is grayed out in your own UI proves that the internal backend process is dead or unresponsive.
    Please escalate this ticket to the R&D. This is an internal firmware bug, not an external vendor issue.
    Regards
