I noticed today that the Tedee lock plugin no longer works - neither scenes nor direct interaction via device preview. It neither locks nor unlocks anymore.
Locking/unlocking directly from the Tedee app works - as well as via the Home Assistant integration.
Can you please have a look into that issue? Thanks!
3 answers to this question
I also experience the same issue from time to time – the Tedee plugin stops working. Removing and re-adding the plugin fixes the problem, but it would be nice if it worked continuously without requiring any intervention. While quickly searching the Tedee API documentation for the word “expired”, I found some references to token expiration. So perhaps the token expires after some time and the plugin is unable to refresh it properly?
    As a first measure, I did recreate the token - no change for the better!
    I‘ve deleted and re-installed the plugin - now it‘s working again! Don‘t know what failed in the first place …
