Shelly_IP101.vfib 1.0.0
   (0 reviews)
A new version of this file is waiting for approval.
This VD is a interface to the ping_shelly.lua which can also be found here. The IP-address needs to be configured as shown in the image. The port value ("109") is used/misused to set the number of the lua script in your HC2  ("_lua").
As example here the code for the "on" button:
local _self=fibaro:getSelfId()
local _addr=fibaro:getValue(_self,"IPAddress")
local _lua=fibaro:getValue(_self,\"TCPPort\")
fibaro:startScene(_lua,{_addr,"on"})
fibaro:sleep(1000)
fibaro:startScene(_lua,{_addr})
fibaro:sleep(1000)
local _slider = tonumber(fibaro:getGlobalValue("S" .. string.gsub(_addr,"%.","_")))
if (_slider <= 0)
then
    _slider=10
    fibaro:startScene(_lua,{_addr,_slider})
fibaro:call(_self,"setProperty","ui.brightness.value",_slider)
Edited by Theo
Other Files from Guest
