Showing results for tags '3 click scene'.
  1. Hi, I can't seem to get scene activation on my dimmer module to work. I would like to activate a scene when a light switch is pressed x3. I'm using a momentary switch and have set parameter 28 to allow scene activation on the module. It works is I run the scene in HC2, but not if I click the momentary switch. Any suggestions? The aim is to activate a scene when I leave home. Not sure how to copy the coding - but here is a copy. --[[ %% autostart %% properties 16 sceneActivation %% events %% globals --]] local startSource = fibaro:getSourceTrigger(); if ( ( tonumber(fibaro:getValue(16, "sceneActivation")) == 15 ) or startSource["type"] == "other" ) then fibaro:call(154, "turnOff"); end Thanks
