Showing results for tags '5 wire roller shutter motor'.
  1. I've connected to my sunshade the roller shutter 2 module, but it cannot calibrate because the motor consuption is only 0.7 w costantly!! My roller shutter motor is not like normal...it has 5 wires! (earth - live - neutral - up - down) I think that probably there is not consuption between neutral and up/down wires, because they only send signal...and the consuption will be between live and neutral!! Any suggestion about connecting it correctly??
