Showing results for tags 'ABUS Secvest VBS LUA'.
  1. Hi ! Ist there any way to get this VBS Script working with the Home Center 2, maybe as virtual Device, to set and unset the alarm and Display the status ? The following is a working VBS Script, i am not good a programming... '========================================================================== ' ' VBScript Source File -- Created with SAPIEN Technologies PrimalScript 2007 ' ' NAME: ipsecvest.vbs ' ' AUTHOR: Dietmar Klein ' DATE : 29.12.2011 ' ' COMMENT: ' '========================================================================== 'On Error Resume Next If WScript.Arguments.Count <> 4 Then WebError("Wrong number of arguments") strHost=WScript.Arguments(0) strUsername=WScript.Arguments(1) strPassword=WScript.Arguments(2) strCmd=WScript.Arguments(3) strOverview="getOverviewStatus.cgi" strStatus="getMode.cgi?Source=Webpage" strIntern="setMode.cgi?Mode=PartSet&Source=Webpage" strExtern="setMode.cgi?Mode=Set&Source=Webpage" strOff="setMode.cgi?Mode=Unset&Source=Webpage" strNative=Right(strCmd,Len(strCmd)-6) set objHttp = WScript.CreateObject("WinHttp.WinHttpRequest.5.1") If objHttp Is Nothing Then Set objHttp = WScript.CreateObject("WinHttp.WinHttpRequest") LogonSecvestIP strHost,strUsername,strPassword Select Case lcase(strCmd) Case "overview" wscript.Echo CmdSecvestIP(strHost,strOverview) Case "status" If left(CmdSecvestIP(strHost,strStatus),10) = "Mode=Unset" Then WScript.Echo left(CmdSecvestIP(strHost,strStatus),10) Case "intern" tempStatus=CmdSecvestIP(strHost,strStatus) If left(TempStatus,12)<>"Mode=PartSet"Then If left(TempStatus,10)="Mode=UnSet" Then CmdSecvestIP strHost,strIntern else CmdSecvestIP strHost,strIntern Do While instr(CmdSecvestIP(strHost,strStatus),"Mode=Busy") > 0 wscript.sleep 500 Loop CmdSecvestIP strHost,strIntern End If End If Do While instr(CmdSecvestIP(strHost,strStatus),"Mode=Busy") > 0 wscript.sleep 500 Loop WScript.Echo CmdSecvestIP(strHost,strStatus) Case "extern" tempStatus=CmdSecvestIP(strHost,strStatus) If instr(TempStatus,"Mode=Set")=0 Then If instr(TempStatus,"Mode=UnSet")<0 Then CmdSecvestIP strHost,strExtern else CmdSecvestIP strHost,strExtern Do While instr(CmdSecvestIP(strHost,strStatus),"Mode=Busy") > 0 wscript.sleep 500 Loop CmdSecvestIP strHost,strExtern End If End If Do While instr(CmdSecvestIP(strHost,strStatus),"Mode=Busy") > 0 wscript.sleep 500 Loop WScript.Echo CmdSecvestIP(strHost,strStatus) Case "off" CmdSecvestIP strHost,strOff Do While instr(CmdSecvestIP(strHost,strStatus),"Mode=Busy") > 0 wscript.sleep 500 Loop WScript.Echo CmdSecvestIP(strHost,strStatus) Case Else If Left(strCmd,6)<>"native" Then WebError("Unknown command") strCmd=Right(strCmd,Len(strCmd)-6) WScript.Echo CmdSecvestIP(strHost,strCmd) End Select Function LogonSecvestIP(strHost,strUsername,strPassword) objHttp.Open "POST", "http://"&strHost&"/login.cgi" objHttp.Send "Language=english&UserName="&strUsername&"&Password="&strPassword strResponse=objHttp.ResponseText End Function Function CmdSecvestIP(strHost,strCmd) objHttp.Open "GET", "http://"&strHost&"/"&strCmd objHttp.Send "" If Not (objHttp.statusText = "OK") Then WScript.Echo "Error: " & objHttp.statusText WScript.Quit Else CmdSecvestIP=objHttp.ResponseText End If End Function Function WebError(Errormessages) WScript.echo Errormessages WScript.Quit End Function
