Showing results for tags 'About HC2 host to backup and'.
  1. Backup once the day before yesterday, and then this morning I changed several virtual device icon, Then make a backup, but when I was in the backup is not the sort of normal backup page appears, but page will automatically refresh after click backup, without backup completion. Try the way is still not successful: 1. The host to restart 2. Part of the backup file to the previously deleted 3. Will be back to the U disk to insert After the failed to create backup, try to use the previous backup to reset, After a timeout to refresh the page refresh after the above screen time and starting from 0, and constantly refresh the web page has been reset time starting from 0 backup images. Mobile phone and tablet login account can operate. Reset the backup image to disappear after cut off the power to restart. Now the problem is that the host can't make a backup, unable to reset the backup file, delete the previous backup file, now only four new backup files, should save full documents do not exist.
