Showing results for tags 'Asociation Group ID'.
  1. Hi. I'm trying to do some simple things using associations. But I'm not able to get it working the way I want. Three relay switches are involved, one Double Switch and two Single Switches. I managed to associate the first switch in the double-unit with the first single switch. Works as I expected. First button on the Double Switch will now also affect the first Single Switch. Next I wanted to associate the second Single Switch with the second switch in the double-unit. Results are confusing. In 4.040 the settings would simply just not be saved. Now after upgrade to 4.042 the UI is behaving strange. I navigate to second Single-Switch and press the "Set Up" button for a Group-ID. I tick the unit that represent the second switch in the double-unit and then the UI will automatically tick the unit which represent the first switch in the double-unit as well. Is it not possible to make individual associations for the different buttons on a Double Switch? Or is this simply a bug? Also, most of my units have Group Id associated with "1". But a few have three Group Id's associated with "1". Why does it differ? Which is correct? Appreciate any clarifications.
