Showing results for tags 'Energy consumption NQ-9021'.
  1. Hi I now see that the NorthQ NQ-9021 is supported in HC2 with a template, thanks! The next step should be to include this device in the Energy Panel. The reason for this is that the NQ-9021 can connect to the consumption meter at the electricity main input of the house (or apartment), and will give the total consumption figure of everything. Such a figure is quite difficult to achieve by summing metrics from various actuators(as the system currently can), since many of the electrical appliances cannot (and need not) to be connected to an actuator. Such a device can be the electrical water boiler, floor heating etc. Also, adding energy measuring actuators everywhere is a big and expensive job. So, I think the only way to easy obtain an total consumption figure for the house is to enable the NQ-9021 for the energy panel(which btw looks very good). Going an additional step further the instantaneous power can also be calculated using the kWh-figures enabling the NQ-9021 for the power panel. Fibaro, can you please consider this?
