Showing results for tags 'Event Log SQL'.
  1. Hi At present, I am running 4.033 and have always found that the Event Panel does not hold sufficient history. At max, it seems to hold 2 days worth of data. While trying to scroll thru 2 days worth of events, I find that the Event Panel is non respondant some times. This is wholly insufficient for creating any analytics on temperature/humidity history as well as other alerts. I am sure it would be possible to read this information into a SQL database or even access and then we could use it for creating more analytics. I raised a ticket with [email protected] and their answer was plain and simple. "You cannot check these data. You can check it in Event Panel, or Consumption". Is anyone aware of any ways of running a batch that I can setup which would query this info using LUA and then dumping it into a SQL table? Thanks Raj
