Showing results for tags 'FGK 101'.
  1. Hi all. Having a bit of an issue with the Fibaro HC 2 and the Fibaro FGK 101 Windows Sensor. The battery ran out in it so replaced the battery. When i put the top cover back on after connecting it, for some reason it lost the association with my HC2 and would not get picked up at all. Thought i may have wiped it So my plan was to remove it from the system and re add it I clicked on remote Z-Wave Device and this removed cleanly, I then tried to delete the device from the device list on the HC2 and it seemed to go. When i refreshed the page, the device came back. There is also a temperature sensor hooked up to it and this does the same; try and remove it, looks like it has been removed, refresh the page and it is still there. I have tried in IE, Chrome and on my Mac but still it will not remove I have managed to re add the Door sensor and Temp sensor and these are working well. Just want to get rid of the 2 rouge devices. Can anyone help me at all. Thanks, Hal
