Showing results for tags 'FGRGB-101 input module'.
  1. I have a Fibaro RGBW module that I want to use as an input module. i.e door bell, dawn to dusk input etc. I have set the controlled device property as input/output, I now want to change to a custom icon with just a on/off state, for some reason I only get the option of adding ten levels of icons. Is the a way to set the properties to on off rather than dim level? Thanks
