Showing results for tags 'FGRM 222'.
  1. Hi, i use a Fibaro FGRM 222 Roller shutter with fhem and a new electronic motor with obstacle detection. The limit switches are set and the blinds can be operated with normal switches. With the FGRM 222 i have a problem. The calibration was successful. When switching the relay is closed and the LED lights up. Then the relay drops off again directly and the motor does not work. After switching 4 to 5 times the motor moves. With a mechanical motor, the actuator is functioning properly. Can you change a parameter so that the motor works with the fibaro actuator? Please excuse my bad english.
