Showing results for tags 'FTcpSocket ErrorCodes'.
  1. I stil have continuing problems with this errorcode = 2, LUA code is like this: function IP_Send(Code, IP, Port, Message_Header) message = "" bytes = 0 errorcode = 0 try = 1 tcpSocket = Net.FTcpSocket(IP, Port) tcpSocket:setReadTimeout(50) bytes, errorCode = tcpSocket:write(Code.."\r") tcpSocket:disconnect() while errorCode ~= 0 and try ~= 6 do message = message.."- Försök "..try.." misslyckades att sända "..Code.." , returkod "..errorCode.."!\r" fibaro:sleep(350) tcpSocket = Net.FTcpSocket(IP, Port) tcpSocket:setReadTimeout(50) bytes, errorCode = tcpSocket:write(Code.."\r") tcpSocket:disconnect() try = try + 1 end if message ~= "" then subject = Message_Header.." sänd misslyckades!" fibaro:call(2, "sendEmail", subject, message) return false end return true end IP_Send("SIIRADIO","xxx.xxx.xxx.xxx",23,"Marantz SR7008 IP") And result is an email everytime I get into problemes with transmitting, and it is frequent: - Försök 1 misslyckades att sända SIIRADIO , returkod 2! - Försök 2 misslyckades att sända SIIRADIO , returkod 2! - Försök 3 misslyckades att sända SIIRADIO , returkod 2! Translated: "Trial x was unsucessfull to transmit "SIIRADIO", returncode = 2" It would be great if someone could give any clues to WHY this is happening and WHAT errorcode = 2 is...
