Showing results for tags 'Factroy reset'.
  1. I have a Home Centre Lite controller that is a couple of years old that I now cannot get to appear in Finder or control it. I recently had to change my router and all my ip addresses changed from the 10.0.1.xxx range to 192.168.0.xxx range. When I use a ip scanner I can see the HCL in the scanner and it appears with a ip address of 10.0.1.215 and also shows a mac address and the name of the HCL. When i view the router I can also see this 10.0.1.215 address (all other addresses are in the range 192.168.0.xxx). I have tried every method listed in the fibaro forum to try and factory reset my HCL but with no success. Does anyone have a suggestion to help rectify this problem Thanks Richard
