Showing results for tags 'Feeling a bit short changed'.
  1. This is the second anniversary of the first time I got to a point where my HC2 got to a state that I considered that it did the basics of automation. So another year and again I am back to where I was two years ago. Stable but basic system. HC2 does little more for me now than it did back then. The one thing (plugins) that would make it better is still locked away and no indication when it will be with us. Every change to the system is risky and can go wrong. The limitations on global variables in lua cripples good development and to what advantage? I could have written a system based on on open source in less time than it has taken me to get here for the third time. So it is time to challenge FIBARO with some big questions. Why should I hang around and be loyal and buy your future products? What are you offering me(anyone) as a customer? Is this third time lucky and everything now will be forward not a return route to the same place in a years time? It is clear to me that HC2 is no closer now to the glossy marketing than when I invested. Why is it still not a lot better and when will it be the product the marketing promised?
