Showing results for tags 'Fibaro Dimmer FGD211'.
  1. Hi, I've been installing a lot of Fibaro dimmers (FGD211 v2.2) in my home and it has been a bumpy ride I have to admit. often it takes a cpl of include/exclude cycles till they work as they should (is that normal? am I just unlucky?). Now I have a new problem: i can include a Dimmer FGD211 in Homeseer3, but it does not recognise the manufacturer: Device synchronization needs to create 1 device. Node: 43 Supports Class(es): MANUFACTURER_SPECIFIC_V2, VERSION_V2, CONFIGURATION, ASSOCIATION_V2, MULTI_INSTANCE_ASSOCIATION, SWITCH_MU Node: 43 Controls Class(es): SWITCH_MULTILEVEL_V2, SCENE_ACTIVATION Warning: Node 43 supports the MANUFACTURER_SPECIFIC command class but manufacturer information was not obtained. Cannot continue with t Warning: Could not get the SWITCH command class version for node 43 . Reloading (importing) node information from the controller... Anyone familiar with that problem and how to solve it? I've excluded them in various ways, pressed the B button for dozens of seconds to reset... any further ideas? Thanks for your help Manufacturer not recognised.pdf
