Showing results for tags 'Flower Power'.
  1. Dear Fibaro Experts, Did one of you manage to read out the Parrot Flower Power cloud data with the Fibaro HC2? Parrot has an API: HTTP://developer.parrot.com/docs/FlowerPower that allows to read out the information about the flower status such as water level and so on. It would be great to use this info to trigger e.g. the sprinkler with HC2. If the flower needs water, HC2 turns on the sprinkler system. Did one of you create a VD or scene that allows to readout the Parrot cloud data? Would be fantastic if you could share? Cheers, Alex
