Showing results for tags 'HC2 motion'.
  1. As a beginner to all things Fibaro I need advice on make my simple light scene work as I would like. I can get my Fibaro motion sensor to trigger a scene on my HC2 to turn a light ON ok, and another to turn it OFF after a pre-set time. However I would like the light to stay ON as long as movement is repeatedly detected, in other words I want the motion to reset the OFF timer each time movement is detected. I see the sensor has a "sustain mode" which I think could help here (not sure how to activate this?), but also this would not work if I wanted to have different OFF delays for different times of the day. Is this possible in block programming or do I need to learn some LUA to achieve this? All help appreciated...!
